07 4man running like crap
All Forums >> [OEM Discussions] >> Honda >> 07 4man running like crap Page: [1]
07 4man running like crap - 8/26/2008 11:35:39 AM
oilfieldtrash
the bike has been fine up until now it started acting a fool...black plug i went from the 175 to 170 still fouling the plug i can start it but i have to hold the throttle wide open and it takes it a sec to throttle up then if i let off the throttle it will run for a few min the die like it dumping to much fuel it wont idle right im ready to take a match to it do you think i should try the 165...i have the A/F  screw 2.5 turns out
thanks
BUY MY BIKE HELP A BROTHER OUT
MINE
2000 BIG BEAR(FOR SALE $1500 AS IS)
Custom lift by MUDDERS MAGAZINE
Custom rear disc brake by /\
Stock wheels/tires
Snorkeled
k&n filter
Jetted
FMF pipe--sounds better than i thought
wiseco HC piston & rings (not installed)
WIFES
07 honda 4man
SS108 wrapped with 26" ML
HMF utility
K&N with prefilter wrap
Dynojet kit
2" HL lift
Diamond plate nose guard
RE: 07 4man running like crap - 8/26/2008 12:03:56 PM
toodeep
by chance is the carb drain line plugged, if it is there could be some debris in the carb holding the float open slightly. might also check the choke valve and make sure it's not sticking. might even try with air filter off to make sure it's breathing properly just a couple of thoughts
1995 TRX300FW - lots of goodies
1991 TRX300FW - a few goodies
2001 TRX500FA - stock
My Pics
Mud Performance
(in reply to oilfieldtrash)
RE: 07 4man running like crap - 8/26/2008 12:09:41 PM
oilfieldtrash
ive done all of it with thw airfilter off it does the same thing..drain aint hooked up right now and i opened the screw and gas pours out i think im going to tare down the carb and clean up real good thanks
MINE
Stock wheels/tires
Snorkeled
k&n filter
Jetted
WIFES
07 honda 4man
HMF utility
Dynojet kit
2" HL lift
(in reply to toodeep)
RE: 07 4man running like crap - 8/26/2008 5:48:12 PM
oilfieldtrash
all right everything is clean still getting black crap on plug thing i should go to the 165?
MINE
Stock wheels/tires
Snorkeled
k&n filter
Jetted
WIFES
07 honda 4man
HMF utility
Dynojet kit
2" HL lift
RE: 07 4man running like crap - 8/26/2008 9:57:27 PM
oilfieldtrash
anyone with some advice plz
MINE
Stock wheels/tires
Snorkeled
k&n filter
Jetted
WIFES
07 honda 4man
HMF utility
Dynojet kit
2" HL lift
RE: 07 4man running like crap - 8/26/2008 10:09:28 PM
matprice
if your re jetting after a snorkel... i went from a 168 main down to a 140 somthing and had to shim the needle to even get it close on a dyno tune and still was a spec rich on the bottom
Mat Price
BitMore Performance Race Team
mine BITMORE TUNED
2007 Can Am 800 Outlander
2007 outlander 800 xt
RE: 07 4man running like crap - 8/26/2008 10:13:06 PM
oilfieldtrash
well when i had the stock jet in it wouldnt run right i put in the 175 and it ran good for a while and now it actin up im going to try the 165 tomorrow and play with the needle a little
MINE
Stock wheels/tires
Snorkeled
k&n filter
Jetted
WIFES
07 honda 4man
HMF utility
Dynojet kit
2" HL lift
(in reply to matprice)
