06 king belt help
06 king belt help
All Forums >> [OEM Discussions] >> Suzuki >> 06 king belt help Page: [1]
06 king belt help - 7/23/2008 11:18:57 AM
kq99
Anyone know if there is any easier way to remove the belt on a 06 king? any help would be appreciated
RE: 06 king belt help - 7/23/2008 12:09:28 PM
KQ4Brad
An easier way??? It is pretty easy right now. Open up the secondary by using 2 of the screws that hold the clutch cover on. the 2 screws will open the secondary allowing the belt to drop, then there should be enough room to take it off the primary side.
07 KQ Black, UNI Air Filter, WES Industries Rear Box, Rear fender protectors w/footpegs, 25" Outlaw MSTs, 3000# Venom Winch, Synthetic Winch Rope, Kimpex Front Bumper, Copperhead VDI, EPI Yellow Spring, 18g Rollers, Coop mods #1 & 2, Yoshi Exhaust, M109R Injector, Machined ITP SS212s*********2000 Polaris Magnum 325
(in reply to kq99)
RE: 06 king belt help - 7/23/2008 12:12:44 PM
kq99
really appreciate it man! havent worked on that yet. got another question. i drowned my king and i know some water and whatever else got in the belt house. any recommendations on what to clean it all out with? water or some cleaning agent?
(in reply to KQ4Brad)
RE: 06 king belt help - 7/23/2008 3:27:21 PM
KQ4Brad
Soapy water and a scrub brush and then rinse it all out good
(in reply to kq99)
RE: 06 king belt help - 8/3/2008 1:04:28 PM
kq99
Thanks alot bud. you seem pretty knowledgable about this stuff. this is my 1st wheeler. got another question for ya. well the belt looked fine and all. not as dirty as i thought it would be but it feels like it keeps slipping. well for instance when im stopped and i hammer it it feels like it takes a second for something to engage instead of going right when i hit the throttle. it does it most of the time but not all the time. any ideas??
RE: 06 king belt help - 8/3/2008 1:16:59 PM
Solitude
Your rollers could be dirty, or your just experiencing the KQ lag. The belts bad if its starting to fray or get glazed over on the sides.
Rhino 660 SE - Lots
King Quad 700 - Lots more with TURNER AXLES and STATELINE CUSTOMS 8" LIFT
Grizzly 660
Rubicon 500
(in reply to kq99)
RE: 06 king belt help - 8/6/2008 12:54:44 PM
kq99
thanks solitude. great help man. like i said though this is my 1st wheeler so never really worked on them. i looked at the belt and i think it looked fine but who knows. so if the rollers are dirty what can i do about them or is it something i have to take to a dealer? any other ideas? oh and it doesnt slip in low gear???
(in reply to Solitude)
RE: 06 king belt help - 8/6/2008 12:59:42 PM
king_quadder
It is to that hard to take the rollers out and clean them up, do you have an impact gun to remove the retaining bolt? If not you may have buy or build a clutch holding tool.
HL Forum moderator
05' Green King quad 700EFI
CATVOS 6" LIFT/ 23" of ground clearance
Boondocker NOS /adjustable regulator
Boondocker fuel controller
(4) 31x11x14 Outlaws on ITPs
Highlifter springs
EPI lime green secondary spring, comp stall springs, 16 gram weights, shimmed primary
Highlifter Pro belt
Fully snorkelled
HMF utility exhaust
Twin Air
Catvos Temp and volt guages
Power Madds
EBC brakes
(in reply to kq99)
RE: 06 king belt help - 8/9/2008 10:31:13 PM
camo king
I have a 07 king quad camo. Is there anyway to keep the clutches dry when you go through a deep mud hole?
(in reply to king_quadder)
RE: 06 king belt help - 8/10/2008 12:27:27 AM
Solitude
Snorkle it!
Rhino 660 SE - Lots
Grizzly 660
Rubicon 500
(in reply to camo king)
RE: 06 king belt help - 8/10/2008 5:37:23 AM
4man0822
ORIGINAL: camo king
     And seal up the belt housing real good! A good bead of Ultra black around the gasket & put back together! Good luck & holler if/when you need anything else!  Later             Brandon
My new ride= 08 750 King Quad Belt snorked, vdi/injector combo. Coming next week=epi yellow spring+18 gram rollers & 2mm shim mod!
filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope Soon to have a clutch kit. 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex box=Sold...
RE: 06 king belt help - 8/13/2008 6:12:05 PM
camo king
This may be a dumb question. If i change my secondary clutch spring so i have to change the rollers.
(in reply to 4man0822)
RE: 06 king belt help - 8/13/2008 6:12:53 PM
Solitude
No you dont HAVE to but it sure will help.
Rhino 660 SE - Lots
Grizzly 660
Rubicon 500
0.391
