06 brute busting up. valve lash?
All Forums >> [OEM Discussions] >> Kawasaki >> 06 brute busting up. valve lash? Page: [1]
06 brute busting up. valve lash? - 8/31/2008 12:14:17 PM
fouz
what its doing: its busting up at low rpms. like its running out of gas. but if you can get past this it will run wide open to a max speed of 67 mph. so one night i run the crap out of it thinking i got bad gas/water in the tank (after draining the tank and refilling) i let my bother-in-law run it down the road. he comes back and i see the exhaust pipe is glowing red. i have cleaning the carbs, put fresh gas in, changed the plugs. can the valve lash be doing this? this is the only other thing i can think of. i got it used and the maintenance on the brute is unknown. so dunno if the valve lash has ever been done. brute has 1600 miles on it.
please help.
RE: 06 brute busting up. valve lash? - 8/31/2008 12:20:02 PM
fouz
please help.
when i say busting up. i would say between 5% to 10% throttle its like someone turns the key off and then when you release the throttle it goes back to running.
errr.  sorry for double post. hit reply instead of edit.
< Message edited by fouz -- 8/31/2008 12:21:27 PM >
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/1/2008 9:59:47 AM
jcbones
It's lean, way lean
Yours truly,
Long Time Lurker!
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/1/2008 10:05:57 AM
devildog12210
What do the plugs look like? I bet WHITE!
(in reply to jcbones)
RE: 06 brute busting up. valve lash? - 9/1/2008 1:52:01 PM
fouz
ill check the plugs but the bike was running fine and then out of the blue this started. so something had to changed some where on its own. s/1 on a diff forum said the diaphrams working the sliders may be the cause. ill check them closer.
(in reply to devildog12210)
RE: 06 brute busting up. valve lash? - 9/1/2008 2:02:40 PM
teamcovert
my buddies is doing the exact same thing. and it just started out of the blue
02 Grizzly 660
27" Vampires on C-Series type 4
1.5" wheel spacers front, 1" wheel spacers rear
Pro Flow K&N filter
Edlebrock Carb
HMF full pipe
EPI clutch
Full Alum skids
3.0 Warn
PROCOM CDI & Rectifier
Works Perfromance AT-Steeler shocks
00 Team Alba Wolverine
08 Polaris RZR
26" Mudzillas on Vision 161
Red HL roof
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/1/2008 4:53:01 PM
fouz
i didnt notice the glowing pipes till we ran it at night. is hes doing the same? PLEASE, if you find out the problem let me know. ill do the same. it is weird. when you first start it will act like it runs fine, besides the cold nature of the brute. then after its fully warmed it seems to start.
< Message edited by fouz -- 9/1/2008 4:54:32 PM >
(in reply to teamcovert)
RE: 06 brute busting up. valve lash? - 9/1/2008 4:57:19 PM
GoatManx
When you pull the choke out does it get better or worse?
Headers are going to glow at night.... that isn't instantly a sign of it being lean and besides that his problem is right off idle.
Brute Force 840 V-Twin
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/1/2008 8:10:00 PM
fouz
no. the muffler was glowing.
the choke. i cant remeber right off hand but ill try it.
(in reply to GoatManx)
RE: 06 brute busting up. valve lash? - 9/1/2008 8:26:34 PM
GoatManx
Stock exhaust or aftermarket? Make sure the stock exhaust isn't clogged up... will hold a lot of heat.
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/1/2008 9:10:16 PM
fouz
stock
RE: 06 brute busting up. valve lash? - 9/1/2008 9:15:25 PM
teamcovert
my buddy has muzzy exhaust and is acting the exact same
02 Grizzly 660
Pro Flow K&N filter
Edlebrock Carb
HMF full pipe
EPI clutch
Full Alum skids
3.0 Warn
08 Polaris RZR
Red HL roof
(in reply to fouz)
RE: 06 brute busting up. valve lash? - 9/22/2008 12:12:55 AM
fouz
s/1 else on another forum said theirs was doing the same thing and it was the chock cable. im replacing mine this weekend. will let you know.
RE: 06 brute busting up. valve lash? - 9/26/2008 6:08:44 PM
fouz
installed new chock cable and some springs from the hardware store for the chock plungers. PROBLEM FIXED.  tell your friend to try it.
(in reply to fouz)
