06 V2 blowing ignition fuses
All Forums >> [OEM Discussions] >> Arctic Cat >> 06 V2 blowing ignition fuses Page: [1]
06 V2 blowing ignition fuses - 11/9/2008 5:42:15 PM
js6ha
Has anybody else had this trouble. I know the problem is the obvious that a wire is grounding out and blowing the fuse but i thought someone might know exactly where I need to look. I also noticed that it blows sometimes where I grab my brake lever.
2006 Arctic Cat V2
EPI Clutch Kit
29.5 OUTLAWS
HMF Utility Series
DynoJet Jet Kit
K&N Airfilter
Homemade 2" Lift
Custom Snorkels
Relocated radiator on front rack
ProGrip handlebar grips
RE: 06 V2 blowing ignition fuses - 11/9/2008 5:59:45 PM
Bunk650
I had it happen to mine. Its an 04 and I found wires rubbing the frame down the steering shaft. Had to take front plastics off and found a burr from a weld that rubbed through the insulation of the wire and was blowing fuses all day...
HPAC
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
Pink Primary
Red Secondary
Custom Teflon Shock Bushings
28" Gators
2.5 Warn
Myspace
(in reply to js6ha)
RE: 06 V2 blowing ignition fuses - 11/10/2008 5:31:52 PM
js6ha
I unplugged the wires that go to the hand brake and that kept the fuse from blowing but now i cant get my gauge cluster to work
2006 Arctic Cat V2
EPI Clutch Kit
29.5 OUTLAWS
HMF Utility Series
DynoJet Jet Kit
K&N Airfilter
Homemade 2" Lift
Custom Snorkels
(in reply to Bunk650)
RE: 06 V2 blowing ignition fuses - 11/10/2008 6:43:50 PM
cat500mudder
I had the same problem on a 07 500m, it was a combination of a chaffed wire on the steering shaft coming from the pod, the 4x4 actuator wires rubbing on the steering shaft, and fan wires rubbing on the same shaft. All three were causing it to ground out. I just wrapped them with rubber tape, and zip tied all the wires away from the shaft
2007 650 H1
Speedwerx pipe
Clutch kit
Jet kit
Snorkeled
Relocated
Outlawed
Nuked
(in reply to js6ha)
RE: 06 V2 blowing ignition fuses - 11/11/2008 4:12:55 PM
js6ha
Catmudder500 was your gauge cluster going crazy
2006 Arctic Cat V2
EPI Clutch Kit
29.5 OUTLAWS
HMF Utility Series
DynoJet Jet Kit
K&N Airfilter
Homemade 2" Lift
Custom Snorkels
(in reply to cat500mudder)
RE: 06 V2 blowing ignition fuses - 11/11/2008 6:08:36 PM
cat500mudder
at times, mostly it would go blanks. A few times it would get to blinking though every time i turned, and then would blow the fuse.
2007 650 H1
Speedwerx pipe
Clutch kit
Jet kit
Snorkeled
Relocated
Outlawed
Nuked
(in reply to js6ha)
