06 500 HO loose front wheel bearings
All Forums >> [OEM Discussions] >> Polaris >> 06 500 HO loose front wheel bearings Page: [1]
06 500 HO loose front wheel bearings - 11/5/2008 10:10:38 PM
LAA66
I noticed the other day there is a bit of play in the front end. I think its the wheel bearings. How do you tighten them? Thanks.
RE: 06 500 HO loose front wheel bearings - 11/5/2008 10:22:50 PM
honda/polaris
you would have to replace them
2008 Polaris Sportsman 800 EFI - Polaris LE wheels, 2500# Polaris winch, front Polaris rack extender, Polaris hand guards, reverse override
Pics/Vids
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:42:29 AM
LAA66
How much play is acceptable? I only have 4000 miles would this be normal wear? Thanks.
(in reply to honda/polaris)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 12:01:45 PM
Barras22
4000 i would consider normal wear...heck i'd be happy if mine lasted 400
[><] Team DO WORK [><]
99' Sportsman 335
00' Foreman 450ES
00' Foreman 450S
03' Rincon 650
05' Brute Force 750
06' Sportsman 800EFI
http://community.webshots.com/user/barras650
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 3:25:02 PM
Dirtbmw20
ORIGINAL: Barras22
I was thinking the same exact thing,lol. I'll be tickeled pink if I even get 4000 miles out of my WHOLE bike.
05' Sportsman 500 H.O.
Rubber Down 3" Lift
Lots of "goodies" I couldn't afford
Dirtbmw20's Pics
(in reply to Barras22)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 5:48:10 PM
LAA66
Sounds like you guys ride them pretty rough to only expect 4000 miles. Mines been on mostly smooth roads on the place i ride. It's  higher speeds that's why so many miles.
Checked the bike on the stand and it is the wheel bearings that are loose. The left side moves back and forth about 1/16"  at the rim to strut location, the othes side is just noticable. Do they need to be replaced?
(in reply to Dirtbmw20)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 6:11:02 PM
REBELRIDER
If you let them get real bad, it will eventually rub the speedo sensor and ruin it...........................
07' Polaris 700
29 Outlaws
AAEN
Snorkt' Through The Tunes
Visions
Keystone Light
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 6:17:59 PM
jay
Also If the bearing ever seizes it will spin in the strut damaging it. Then you either have to take it to a machine shop to have oversized bearings put in or replace the strut.
05 popo 700
jetted
K&N
800 header
white brothers exhaust
front and rear brushguards
2" HL lift
29.5 laws
odessey battery
stealth snorkels
heelclicker
wifes ride
05 popo 400
26" outlaw mst on climax wheels
(in reply to REBELRIDER)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 7:42:29 PM
LAA66
So these are not tapered bearing races?
(in reply to jay)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 7:47:48 PM
mud_duck
No. the bearing is pressed into the strut housing.
'04.5 Polaris
TEAM CRUSHLOK Powered By Miller Industrial
CLICKMy Pics
______________________________________________
I may be old, but I'm not boring
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 8:42:14 PM
LAA66
Thanks for the replys. Does it seem with that amount of play the bearings need to be replaced?. Is it a common maintainence item?
(in reply to mud_duck)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 8:47:54 PM
SouthBossierGrizz
This is a common maintenance replacement.  I would go ahead and take care of it now while there is no damage done.  Like the other guys have stated, you don't want to let them get bad.  Once they start going out, they usually go quickly.
Team High Lifter/Polaris Racing
2008 Polaris 800 H.O. (Bayou Snorkels built motor)
2009 Ranger RZR-S (Bayou Snorkels built motor soon)
2009 Ranger XP (Bayou Snorkels built motor)
2009 Sportsman 850 XP
2009 Sportsman 550 XP
Sponsors: High Lifter Products, Polaris Industries, Pure Polaris, Supertrapp, Hot Seat Performance, Bayou Snorkels, Ogio, Warn Industries
www.myspace.com/bayousnorkels
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:10:25 PM
LAA66
So just buy bearings, or do the races need to be done also? Is it like an automotive type replacement?
(in reply to SouthBossierGrizz)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:16:52 PM
SouthBossierGrizz
What year is it?
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:23:26 PM
SouthBossierGrizz
Duh....I see that it's an 06 model.  You will just need the bearings, about $65 each.
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:35:22 PM
LAA66
From which supplier. TK's
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:36:34 PM
SouthBossierGrizz
I alway use bikebandit.com for OEM parts.
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:44:06 PM
mud_duck
Local autoparts store. Ferderal Mogal # 510014 for the front 510013 for the rear.
Most stores have the rear in stock. The front you'll most likely have to order.
'04.5 Polaris
CLICKMy Pics
RE: 06 500 HO loose front wheel bearings - 11/6/2008 9:46:56 PM
mud_duck
You can also google All Balls Bearings.
'04.5 Polaris
CLICKMy Pics
RE: 06 500 HO loose front wheel bearings - 11/7/2008 2:54:32 PM
LAA66
Just these last few questions. Bye the way thanks for the help. Any preference on bearing brands? I found BCA, and Timken so far? Also does the bearing come right out after removing the snap ring or must it be punched out from the CV side.
RE: 06 500 HO loose front wheel bearings - 11/7/2008 4:03:18 PM
riblet
Not sure on the brands, but it will need to be punched out or pressed out.
06 Polaris Sportsman 800 EFI
29.5 Outlaws
Viper winch w/ green amsteel
2" lift
1" spacers
snorkel in pod
Dirtbmw20 rad relocate
split audiopipe
RD Bar Ends
RD fairlead
Death Grips
(in reply to LAA66)
RE: 06 500 HO loose front wheel bearings - 11/7/2008 8:17:40 PM
honda/polaris
i used all balls. got them all for 100 bucks. ya the bearing will have to be pressed or punched out from the cv side. you might as well replace them now before they go out and damage something.
Pics/Vids
(in reply to riblet)
Post #: 22
RE: 06 500 HO loose front wheel bearings - 11/7/2008 9:08:09 PM
ORIGINAL: mud_duck
Yeap they sell good bearings and a good price.
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
Post #: 23
RE: 06 500 HO loose front wheel bearings - 11/26/2008 2:22:00 PM
LAA66
 Got the bad front bearing replaced yesterday and it solved the problem. Took about 2 hours but the rest will go faster now Ive done one.
All Balls Bearings couldn't sell to me because I'm not a shop. Went thru Bike Bandit, which had a Moose kit, which was labled ABB. Same price too. Go figure. Timken is the brand on the fronts bye the way. Tks again.
(in reply to GWC)
Post #: 24
