03 big bear problems
All Forums >> [OEM Discussions] >> Yamaha >> 03 big bear problems Page: [1]
03 big bear problems - 12/2/2008 7:26:56 PM
09bigbear
was wondering if anybody knew a good place to get a cdi box for my 03 bb.it turns over good just not getting no fire
RE: 03 big bear problems - 12/2/2008 10:40:22 PM
txgrizz9
hhhmm try and put a new spark plug in that is a cheap way to check if it will fire up
05 Grizz
9'' lift
high rev box
audio formz
30'' backs
custom snorkel
moose clutch kit
warn bumper
g-axles
fmf exhuast
k/n
jet kit
relocated radiator
(in reply to 09bigbear)
RE: 03 big bear problems - 12/3/2008 5:35:47 AM
Dezz
Are you 100% sure that it is the CDI box?
I ask this question because these units are usually very reliable, and don't fail to often.
Also, a commen component in Yamaha atv's to go (which causes no spark) is the Pick-Up coil (or Pulse Coil to some people). When this component fails, no spark is created because no voltage is induced to charge (pulse) the ignition coil.
The Ignition coil is also a part that fails more often than a CDI unit.
Both can be checked using a Multi-meter and measuring the resistance within each unit. I do not know the numbers that you should look for, but any good Yamaha ATV repair manual for your specific model should have them.
I would check these components first before buying a CDI box without actually testing it ,as cdi units are not cheap (no matter where you buy them from), and there are other components that fail more commenly.
Good luck with it.
Dezz
1998 Grizzly 600
ITP Delta Black Chrome Rims
Uni Air Filter
Warn A2000 Winch
Detroit Gearless Locker
Oxlite CV joint protectors
(in reply to txgrizz9)
