( T CAT ) SPEEDWERXS CLUTCH ???
All Forums >> [OEM Discussions] >> Arctic Cat >> ( T CAT ) SPEEDWERXS CLUTCH ??? Page: [1]
( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 1:36:50 PM
oldpepsiman
Has anyone installed a speedwerxs cluteh mod? what did it do for you ?
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 1:47:37 PM
Dreggsta
i had one in my '07 700. it def gave it a lower starting gear w/some more aggresive backshifting.
Team Southern Swamp Boyz
'08 700 H1 SE
Nology Coil & Wire
LE Front & Rear Bumpers
Big OG Racks
Warn 3k Winch
Powermadd Hand Guards
Moose Hand Grips by O.D.I.
High Lifter Springs
4.0 Gears
B & J Customs 2.5" Lift
ITP 14x8 SS 212's Machined Silver
Gorila Sliverbacks 30x11x14's On All Four Paw's
Rad Racked (MudTechInc)
Gorila Axles
Fully Snorked w/Pre-filter
Exhaust Mod & Snorked
(in reply to oldpepsiman)
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 2:05:04 PM
BuLLg0d
I run a speedwerx in mine an love it. It hits harder than the dalton on low end.
08 ARCTIC CAT 700H-1
09 Thundercat TRV
TEAM STEEL HORSES
POWERED BY ARCTIC CAT
Moto Sport Alloy
CATVOS
Gorilla Axles
Speed Werx
08 c.m.r. mudfest 3rd place swamp x open class
08 springcreek mudbog series 2nd place open class
08 hlpsr mckinney 3rd place mudbog pro a class
08 c.m.r. mudstock 3rd place mudbog class 3
08 mud fest unleashed 3rd place 650 up class
08 mud fest unleashed 2nd place open class
(in reply to Dreggsta)
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 2:13:05 PM
oldpepsiman
right now i have plenty low end .i'm looking to increase the top end.
(in reply to BuLLg0d)
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 2:15:14 PM
BuLLg0d
You cant pick up any speed because the limiter will stop you at 83mph
09 Thundercat TRV
TEAM STEEL HORSES
Moto Sport Alloy
CATVOS
Gorilla Axles
Speed Werx
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 2:22:46 PM
engie
read the sticky thread on clutching to pick up top speed! There is alot of room to modify that fixed plate on the thundercats for more top speed at the same rpm.
If the ecu is shutting down based on speed and not rpm, then you will need to unplug the speed sensor!
Building a few motors with another innovation or two...
04 Eiger Auto - Going to Flynts' for vacation...
Parting out 06 Cat700...
A bunch of Eiger Parts and Can-Am clutches for Sale!
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 5:59:49 PM
oldpepsiman
hey guys response is great but were do i go to read a stickey thread?
(in reply to engie)
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 6:03:27 PM
Dreggsta
http://www.highlifter.com/forum/Arctic_Cat_Tips_and_Helpful_Information%25%25%25/m_2371412/tm.htm
'08 700 H1 SE
Nology Coil & Wire
Big OG Racks
Warn 3k Winch
High Lifter Springs
4.0 Gears
Gorila Axles
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 6:06:07 PM
oldpepsiman
left off a couple things raceing my tc up olds at glamis got 42mph, flat drags got 62mph.
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 9:04:02 PM
oldpepsiman
the clutch mod i'm asking about is a 08 Thunder cat 1000
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 9:25:05 PM
the TC has the same clutch set up as the 650H1 and 700H1, you can do the secondary clutch mod to it to gain more lowend snap, tighten the belt and give it better bake shifting, add light rollers to hold it in a lower gear ratio for a longer time or heavyer rollers to have it up shift faster for you and keep it in a higher gear ratio for higher speed type of rideing.
For what i know i dont think any clutch kits will add top end speed most will take away around 5mph or so but give alot better lowend power. wonder why its only hitting 62mph..?  most TCs will run close to 80mph..
Is yours all stock..?
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/6/2008 10:03:30 PM
oldpepsiman
i've gotten 78 in 1/4 mile on the hiway. up hill at oldsmobile in glamis i would say it's about 350 yrds the flat drags are all in sand about 300 yrds also.
(in reply to GWC)
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/7/2008 9:30:49 AM
T CAT 2
Sand eats horsepower.
ARCTIC CAT THUNDERCAT 1000 H2
Moose Executive Trunk
Tamarack front trunk
Terry cable dual gasser Twist/thumb throttle
Hot Grips
Viper 4500# Winch
Speedworks 25 Gram clutch rollers
VIP Air windshield
Kolpin 1.5 gallon gas carrier
Moose fender bags (2)
GPS and Camera Carriers
Sway bar
Shindy Steering Stabilizer
ITP 212 machined Wheels
GBC Grim Reaper tires
RE: ( T CAT ) SPEEDWERXS CLUTCH ??? - 11/7/2008 11:49:03 AM
ORIGINAL: T CAT 2
yes it does   and the fact the TC is like 700lbs+ does not help it one bit in the sand.
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
(in reply to T CAT 2)
