'06 King Quad Full Custom Snorkel and XP 3" Lift
All Forums >> [OEM Discussions] >> Suzuki >> '06 King Quad Full Custom Snorkel and XP 3" Lift Page: [1]
'06 King Quad Full Custom Snorkel and XP 3" Lift - 7/24/2008 11:57:35 PM
UnConquered*King
CVT Snorkel
~about 10' of 1.5" abs(black) or pvc(white) pipe w/ stacks included
CVT Intake                                   CVT Exhaust
1 - 3" to 1.5" adapter                     6 - 90* 1.5" elbows
(used stock int. boot)                     1 - 2" to 1.5" pipe adapter
2 - 60* 1.5" elbows                              (used stock exh. boot)
3 - 90* 1.5" elbows                        2 - 90* 1.5 elbows for snorkel tops
1 - 1.5" to 1.5" rubber flex adapter    1 - 1.5" to 1.5" rubber flex adapter
1 - band clamp                              1 - band clamp
Airbox Snorkel
~about 3' of 2" abs pipe w/ stacks included
1 Airbox Adapter @ http://www.cometkartsales.com/store/air/boxes.htm look for airbox inner rubber boot at bottom of page.....$10 and well worth it
3 - 45* 2" elbows
1 - 90* 2" eblow
1 - 90* 2" elbow for snorkel (stack) top
1 - band clamp
I used as much black as I could except I wanted to paint alll my pipe red!!  I used marine silicon to seal the box and box adapter..shown below.  I found all of these pieces at Lowe's except for the airbox adapter which as the link above.  I made this so I would be able to take off the plastics leaving the snorkels on the body work and all the plumbing attached to the bike, except the airbox plumbing...there is no room to attach the rubber flex pipe adapter, as you will see below.
This was a very long process so I will not tell you how long it took....good luck.  If you have any questions just ask!
* Sorry the pictures loaded out of order so it gets kinda random in there*
These are all of my mock-up photos with some painted!
http://s46.photobucket.com/albums/f111/scottyg36/Mock-Up/
These are all my finished product pics
http://s46.photobucket.com/albums/f111/scottyg36/Mock-Up/King%20Quad-Finished/
NOTE: To fill the stock intake hole on the airbox, I used to stock rubber piece in the opening and cut most of it off that stuck into the airbox.  I then cut a piece of fiberglass, you can use the lid piece that u will remove to get to this point, and fit it to the rubber pieces opening.  I then marine silicon the entire area, the pictures do not give this thing justice (it will survive a nuke blast!), along with the o2 sensor on the bottom of the box and all the little pop rivet holes from removing this lid.  I also used this silicon to seal the adapter from the link above!!!
HINT:  Use white out, like the stuff u put on paper instead of erasing, and mark all you connections so they will go back together in the right orientation when u start glue'n this stuff together...I told you to save u time and money!
The lift was done by my bro on a night he just couldn't look at the lift in the box any longer, so all I have are the before and after photos!!  no big problems installing this, read instructions.  You need two people to install cause he had issues tightening both sides on the rear at the same time..
< Message edited by UnConquered*King -- 7/25/2008 12:35:12 AM >
'06 King Quad- building stage!
Full ABS Snorkel system
3" XP lift
HL Springs
SS108's w/ 28" laws 10.5's and 12.5's
Yahtzeeeeee!!!
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 7/25/2008 1:33:16 AM
UnConquered*King
Are these pictures working?
3" XP lift
HL Springs
Yahtzeeeeee!!!
(in reply to UnConquered*King)
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 7/25/2008 7:14:27 AM
brokeking
WOW great job looks clean !! mine looks like i was drunk and blind when i did it compared to that.
Awsome ..
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 7/25/2008 8:05:47 AM
Freestyle
Looks real good bro! Thanx for the write up!
08 750 King Quad
3" Xtreme Lift
30X9 Sliverback's
Vision Buckshot Wheels
Twin Air Filter
Full Custom Snorkle
Crankcase mod with Filter
Sealed Pull Start
Greased Shifter
Sealed display
Took spark arrester out
Warn XT 25 rope winch
"Team Scuba"
www.myspace.com/thefreemans620
(in reply to brokeking)
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 7/25/2008 8:51:58 AM
hondanchor
Awesome write up little brother, very well put together. Might need to ask the Admin to make it a sticky KQ thread.
Here are a few words about the lift. The lift was simple, follow directions closely for the rear of the bike. Loc-Tite everything you put back on. Thats prttey much it, it made the bike ride alot better we'll see how it does with the 28" laws. Great write-up Scott, turned out nice.
06' Foreman
28x12.5x12"Laws
ITP Type 7 Chrome Wheels
2" HL kit
HL Springs
HMF exhuast
DynoJet Jet Kit
Triangle Snorkel
Aluminum Products Stick Guards
HL Pullstart Leak Shield
HL Outlaw Clutch kit
(in reply to Freestyle)
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 7/25/2008 9:37:51 AM
coolcloo1019
Wow, that's an awesome writeup. Wish someone had that for an Eiger. lol
Guess I'll just have to document my install and be the first.
2007 Suzuki Eiger 4x4 Auto
- Uni Filter
- DynoJet Kit
"Do work!"
(in reply to hondanchor)
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 10/6/2008 11:50:55 AM
UnConquered*King
Bumpity bump for someone wantin to snorkel their KQ!!!
3" XP lift
HL Springs
Yahtzeeeeee!!!
(in reply to coolcloo1019)
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 10/6/2008 12:47:47 PM
king_quadder
I added your writup to the "sticky" at the top of the Suzuki section!
HL Forum moderator
Waiting for my next new toy!
RE: '06 King Quad Full Custom Snorkel and XP 3" Lift - 10/6/2008 5:21:33 PM
4man0822
ORIGINAL: king_quadder
     Good job Mark, we appreciate it!                            Brandon
4 a single, she hauls!!
filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
(in reply to king_quadder)
