rancherryder
Use marine grade plywood if you're set on the wood box, otherwise build an audiopipe. The MDF board swells when it gets wet. I used plywood on my first 2 boxes. Apply a layer of fiberglass resin, paint it, and it's good to go. It's been on the front of my Rancher for 2 1/2 years and still works fine without any leaks.
2008 Yamaha Grizzly 700 31" Outlaws, 14" SS112, 1.5" Spacers, XPATV Lift, HL Springs, Warn 2500, HMF Utility/Optimizer, Dyna CDI, HL Clutch Kit, Snorkels, Audiopipe
